I go a ddm hid kit for my ellipsoid lights and have some kind of problem. The low beam lights will only turn on when the hi beams are turned on. (they both go on together). I first tested the setup and it worked" hi's and low's went on like normal. I was wondering if I blew a relay or something? Anyone know what could be wrong?
HID ellispsoid install problems.
i take it the connectors showed up?
have someone work your hi beam switch to see if the relay is switching. you should hear it click under the hood. if it is clicking, then look at the fuses, although if they are booth comming on your fuses should be good.
are you running 1 or 2 sets of HID's? (both hi and low beam)seien Sie größer, als Sie erscheinen
