turn signal flashing weird
  • metroya_performance
    • 88
    ok so I replaced all the light bulbs anywhere on the outside of the car now, and everything works now except for the drivers side front turn signal. now, it does light up, and it does flash, but its dim as hell and the whole left side flashes rapidly as if a bulb is burnt out. the rear left one is as bright as it should be but like I said, just the front one is dim on that side. is there anything that could be causing that? and to be honest i didnt even know I had light up sidemarkers til today when I was checking the wiring, and I replaced those bulbs too and they work also now. woo!
  • gearheadE30
    • Jun 2007
    • 3734
    probly a corroded plug or a short in the wiring somewhere. The front signal harness is a known wiring issue in e30s
    Project M42 Turbo
    • Schnitzer318is
      • Jan 2008
      • 2057
      What he said, had the exact same problem with an '87 325 I bought for the wife. Check the plugs that actually go into the lights for corrosion, that's where my fault was.
      "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
      91 318is Turbo Sold
      87 325 Daily driver Sold
      06 4.8is X5
      06 Mtec X3
      05 4.4i X5 Sold
      92 325ic Sold & Re-purchased
      90 325i Sold
      97 328is Sold
      01 323ci Sold
      92 325i Sold
      83 528e Totaled
      98 328i Sold
      93 325i Sold
