VHT Night Shade A++++++++
To make sure the rust doesn't creep around anywhere you don't want to fiddle with, POR-15 it. I actually use a lot of Rustoleum Rust Converter to halt the rust my little '91 318is is riddled with. The rear apron on the driver's side is a straight up hole and right behind the driver's side door the body is seperating from the frame (Sonofabitch PO). Until I can afford to have the car out of comission and paint, it's been stopped. I still check on it every 2 weeks to make sure and while not ideal, it's what I can do ATM.Need a part? PM me.
Get your Bass on. Luke's r3v Boxes are here: http://www.r3vlimited.com/board/showthread.php?t=198123Comment
Thanks for the advice! I'll probably go get some of that tomorrow if I can find it. The body panels hit the hardest are the passenger front fender, and driver's side door. Both are being replaced with rust free parts from California, and the rear bumper is hopefully going to be fixed up by my uncle that does body work for a living.To make sure the rust doesn't creep around anywhere you don't want to fiddle with, POR-15 it. I actually use a lot of Rustoleum Rust Converter to halt the rust my little '91 318is is riddled with. The rear apron on the driver's side is a straight up hole and right behind the driver's side door the body is seperating from the frame (Sonofabitch PO). Until I can afford to have the car out of comission and paint, it's been stopped. I still check on it every 2 weeks to make sure and while not ideal, it's what I can do ATM.
Thanks! They actually got a very nice "OEM" look/texture on the finish, do you think wet/sand and polishing would really help the appearance?2007 Range Rover Sport S/CComment
yea, depending on where you sprayed this, dust speckles and particles got in there,
since the paint is translucent you can see them, a nice polish will take those lights up
a notch or two. its one of those differences you don't really see until you've done it or
experience. but do what makes you happeesigpicComment
I was actually going to go with all reds too, until I saw this paint for $8 :)
I did two coats, but it all depends on how heavy you spray it. I would say that I did medium/heavy coats, but a guy on bimmerfest did 6 coats and his is a little darker than mine. Wait 15-20 minutes between coats. I also stood them up against a wall in my basement to paint them, I think the paint was easier to spray like that..
Go for it! Easy mod and you can lightly tint it or paint certain parts as you please!
I have a friend locally that is going to swap the trim with me off his race car, but thanks for the offer!2007 Range Rover Sport S/CComment
FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
1989 325i - Project/weekend driverOriginally posted by scabzzzzI stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
2002 325i - DD
2005 Suzuki SV650 - ToyComment
wow ive seen some vht smoke jobs and they all looked flat, they never looked so glossy! i gotta try that!
2002 325i - DD
