I'm in the middle of a marathon diving board to plastic bumper swap and after struggling with the wreck damaged frame rail for about 10 hrs - (torch grinder, welder, chains etc.) finally got the bumper pins in, only to discover that I had forgotten to plug in the turn signals/parking lights on the front part of the bumper.
Turns out, the connectors are different on my 88 325 than the 90 I bumper that I purchased. Anyone know what wires go to what male prongs in the light bulb housing. The wires in the harness are brown blue and grey - I assume that the brown is the ground, and similar to the 3 pronged aux fan temp sensor switch, the ground is the terminal not in the same flat plane as the other two terminals. But I'm not sure which way to wire the other 2???
Bought some individual female pin connectors to at least get a temporary connection before I can splice in an actual plug.
Thanks for any help!
