In the middle of installing my HID euro smileys, and here is the problem:
attached low and high beams on pass side no problems, checked both low and high beams with good output and results. Went to do the same to driver side, got the low beam wired up, went to check it, and now it works, but the passenger side low doesn't. Thinking maybe I spliced something into the wrong wire somewhere. I basically matched colors on the low beam wires (white/yellow into white/yellow, and brown into brown) with what had been done previously by the last owner (figured they used the same color wires from the body of their car too)
