Headlight problem
  • ttrousdell
    • Nov 2009
    • 1770
    Headlight problem
    only one of my lowbeams work but when i put it to high beams, all 4 light up. anyone know how to fix this thanks.
    The Build:
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    you may have a burnt low beam element or a blown fuse. sealed beams?
    -Andy
    • QUKBMER
      • 8178
      I second that answer.;)
      • ttrousdell
        • Nov 2009
        • 1770
        ok thanks. you know what number fuse it is or where the lowbeam element is so i can replace. the headlights are regular stock ones. not the ones that look like there is a glass ball in the center
        The Build:
        • QUKBMER
          • 8178
          If it is a sealed beam you replace the whole thing. $15 or $20 bucks i think.
          • dashboardmonkey
            FUCK YOUR WAFFLES
            • Jun 2008
            • 6158
            headlight fuses are #1, #2, #13, #14
            -Andy
            • blck325is
              • Apr 2006
              • 1749
              Had this happen, got lights already. Gotta install and we'll see what happens.
              Originally posted by csermonet47
              Vlad, you are handling this quite unprofessionally.
              Also, you are a cock with tacky taste.
              That is all.
