Driverside tail light not working...
  • Dsobes
    • Jun 2010
    • 34
    It's not the housing, I put the housing on the other side and it worked fine 100%. My fear is that I blew the relay....Anyone ever had this issue?
  • Dolmangar
    • Jun 2010
    • 95
    Are you getting power at the wiring harness plug on that side?
    Oh and is the entire side dead, or just the brake/signal/reverse light? If they are all dead I say something pinched the harness on that side (or bad plug). If it's only one of the lights it could be a relay but I don't happen to know off hand if they share a relay or if there are left/right relays for the rear.
    • DaveSmed
      • Apr 2007
      • 1407
      It is EXTREMELY unlikely your check control relay is damaged. Wouldn't worry about that.
      -Dave
      2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
      Need some help figuring out the ETM?
