Euro smileys
  • Evan12
    • Dec 2010
    • 346
    Euro smileys
    What color are these? Are they bright blueish? Whitish blueish? I'm looking for headlights besides my shitty stock yellow ones. Can someone enlighten me on this?
  • e30trooper
    • 11576
    their greenish
    • Evan12
      • Dec 2010
      • 346
      Lol. For real tho are they bright?
      • IRON-E
        • 16548
        Smilies are a style of headlights. I thinl you're looking for HIDs, which require a ballast and a different light bulb to reflect brighter light.
        @IRON-E30 aka Edwin:D
        • e30trooper
          • 11576
          Super bright dude
          dude your so wrong.....
          • Evan12
            • Dec 2010
            • 346
            Well with the smileys are the bulbs not yellow?
            • e30trooper
              • 11576
              I was just messing with you dude. The Smileys are The light housing not bulbs. In order to have different colors you need to change the bulbs.
              • IRON-E
                • 16548
                Explain it to me Ben, I mean the ellipsoids can be plenty bright with 55watts/8k bulb HIDs and pointed up like a tard.
                • Evan12
                  • Dec 2010
                  • 346
                  I knew u were kidding lol. And ok. So u can get bright aftermarket bulbs? Cuz my stocks don't have many options I don't think.
                  • e30trooper
                    • 11576
                    Hold Up
                    this is the housing
                    this is the bulb
                    this is a HID bulb
                    • e30trooper
                      • 11576
                      Yes.
                      • 2slowe30
                        • Dec 2010
                        • 60
                        What is smileys
                        • Evan12
                          • Dec 2010
                          • 346
                          Thanks.
                          • goml23
                            • 175
                            Originally posted by 2slowe30
                            What is smileys
                            1991 318is - custom dents, loud steering, peeling clear coat, cracked seats. <3 <3
                            WTB: Center caps for Zender Sports.
                            • Mo Brighta
                              • 427
                              yellow what?
                              Are your lights yellow, or is there a surplus of urine in your system making everything look yellow ?
                              Yellow could be a colored bulb AND a color that results when stock clear bulbs get old and dims, usually from low voltage, making the lights look 'yellowish'. OR it may be a European yellow glass (Hella Gelb) originally for use in France, or that was installed by a PO for cosmetic reasons.
                              Can you pull the bulbs out and look at them?
                              What do you see, yellow bulb, yellow glass lens, or just seems yellow cause it's so dim? AFAIK, yellow lights weren't installed in US or Germany.
                              And yes, you can get higher wattage aftermarket bulbs at from 75 up to 130 Watts. Better have some realys and heavy gage wiring above 75 Watts, tho, and you will want to upgrade GROUND wires too. Just steer clear of so-called 'superwhite' or 'HID-Look' bulbs with a blue tint coating.
                              First step, tho, is pull the bulbs and look at them. They have the bulb type (H1, etc.) wattage (55W) and voltage (12V) stamped in them somewhere. And clean the lenses frequently, dust and dirt do not make them brighter.
                              And if/when you buy new lights, get headlight protection film on them to keep them from being broken or sand-blasted or chipped by rocks. $16 a set of four, correct size for BMW lights, just send me a pm or email.
                              Andy says "Be Seen, and Not Hurt!"
                              Lighting Upgrades front and back for 2002, E3, E9, E10, E12, E21, E23, E24, E28, E30, E32, E36, E39, and more.
                              Tail Light Improvements keep them off your tail.
                              Headlight protection saves headlights from breakage.
