Hid problem. Please help!
  • CircuitMonster
    • Jul 2010
    • 271
    Ok so I just installed my hid kit and only my driver side works not the passenger side. But I know it's not the bulbs or the ballast because I switched them first the bulb then the ballast and everything only works on the driver side.. And it's not my wires because my stock bulb still works on the passenger side if I use it. Any ideas?
  • KillaCams
    • Mar 2008
    • 998
    Is your pass wired correctly? If it's correct it may not have enough voltage to power up the ballast from what you are describing.
    • CircuitMonster
      • Jul 2010
      • 271
      Yeah correct stock bulb works and I even upgraded my fuses and still only one side works.
      • CircuitMonster
        • Jul 2010
        • 271
        I tried using the ddm harness too and that makes it so none of them work lol this is getting crazy.
        • CircuitMonster
          • Jul 2010
          • 271
          Goning to be trying 25 fuses to see of they work hope these dot blow with the ddm harness
          • CircuitMonster
            • Jul 2010
            • 271
            No luck looks like only driver side works... Anyone else have Any idea?
            • unrlmth
              • 467
              Not a good idea to "upgrade" your fuses without also upgrading the wiring.
              1989 325i Alpineweiß II
              • george graves
                • 19992
                You swap over the balast and the bulb? (you has some typo in there)
                My guess is you're not getting enough current on the passenger side. Does it flicker at all? Or just no light what-so-ever?
                I'd get a new fuse - and dunk the connector in some vinegar, see if cleaning the contacts help. Dunk in vinegar for 5 mins, then clean water.
                Originally posted by Matt-B
                • CircuitMonster
                  • Jul 2010
                  • 271
                  The passenger side doesn't light at all no flicker nothing. Sorry yeah I swap te bulb then the ballast then both. Still nothing. Sorry for typos I'm on my phone
                  • george graves
                    • 19992
                    Yea, these things need a bunch of current to start up. That would be my guess.
