Rear Fog Lights
  • Imago
    • Feb 2011
    • 5
    Rear Fog Lights
    Hey. I'm currently spending my spare time on a 320i BMW.
    I've kinda come to a halt with my rear fog lights. The switch, globes (and the steel wire loom for it), fuses and shiz all seems to be there, but they don't seem to work.
    It's an imported model (made in '92 and imported to Australia in '95 I think). Theoretically, it's got all the circuitry there, but i'm not sure if there's some weird easter egg kinda thing that needs to be there to make them work?
    It doesn't have front fog lights, but I doubt they need to be installed for the rears to work.
    Cheers for any help.
  • Charley
    • 396
    When I got my car the rear fog wasn't working either, the switch was bad.
    You can use an AC switch to check if the switch is the problem.
    Did you checked the bulb?...
    If its not the switch then find yourself a multimeter and go to work
    • Imago
      • Feb 2011
      • 5
      I've checked the bulbs, they're ok. I'll try and check the switch, or get my multimeter out.
      Thanks.
