Relays
  • BahnE30
    • 1050
    Relays
    which relay is for the daytime running lights, i want these things gone....
    also which relay needs to be modded for foglights without headlamps.
    plus which pins need to be soldered together.
  • BahnE30
    • 1050
    anyone???
    • Jordan
      • 12913
      daytime running lights isnt a relay
      or fuse
      its hardwired.
      haha.
      https://mtechniqueabs.com/
      • BahnE30
        • 1050
        well there's a way and i'm going to figure it out as i hate this thigns, and i know you know so spill it....
        • 92 mtechnic cabrio
          • 4907
          just take teh bulb out.
          R.I.P 07/01/09 - 04/23/10 :(
          • SebSter
            • May 2004
            • 192
            Your daytime running lights will not go away, I guarantee you. A friend was looking into it for 90-91 Canadian e30s, the wiring schematic is so complicated its near impossible.
            The closest you will get to it is driving aroudn with the switch in the middle position, sry.
            As for the foglight mod, run a search its very simple, just bending a pin on a relay and soldering a jumper wire (forget which one though).
            1990 325ix
