replacing bulbs on IX fogs
  • Quik325ix
    • Mar 2005
    • 381
    Hey guys, I just lifted a driver's side fog from Relayer85's wrecked 325i but after being installed in my car the thing wont work. Im thinking that the bulb is dead and needs to be replaced using the standard H4 bulb.... i know this probably sounds dumb, but how the hell do you replace th bulb?
  • Mystikal
    Wheel Fitment Expert
    • 9602
    There are 2 rubber plugs on the front lens, remove the bottom one and remove the screw behind it. The fog assembly will now be able to come straight out, grab it from underneath and push. Now there is a small round door at the bottom of the light, held on by a single screw. Remove that, then you will see the bulb.
    You can also do it on the car, but it's easier to just take it out (an extra 2 mins of work, better than crawling underneath).
    • Quik325ix
      • Mar 2005
      • 381
      Thanks man! much appreciated!
