One blinker blinks faster
    So the other day while driving, my right blinker started acting up, and its driving me nuts
    The right blinker blinks twice as fast as my left one. Left blinker blinks fine.
    Outside the car, both sides of blinkers blink same speed as they do on guages panel. Though, my front passenger side blinker seems to be dimmer than the other..
    My emergency flashers both blink same speed.
    Any thoughts? Its driving me mad
    Time to replace the bulb.
    1991 325iS turbo
      Yup^^
      Originally posted by Gruelius
        blinkers that are acting abnormal as in blinking faster than noramal usually has to do with with bad grounds. Go back over the connections and see if any are fraying or come loose.
        Sam
        Originally posted by Roysneon
        $5 shipped?
        Originally posted by MarkD
        You are a strange dude, I'n not answering any more posts from you.
          Here, let's get fancy though,
          Current runs through whatever circuit is lighting the turn signal. As the current flows through, it heats the fuse to some "critical" temperature, which then clicks the circuit off. After a quick second of time, the switch closes again and the process is repeated.. blink... blink... blink...
          When one bulb is out, more current is flowing through only one of the paths, thus blinking faster.. blink,blink,blink,blink
          1991 325iS turbo
            ground...lol
            $5 shipped?
              Corrosion on the bulb socket. Clean it up with some sand paper. Done.
              '89 Alpine S52 with goodies
                Change the bulb out!
                  I think that's a no brainer. If that doesn't work you would then move on to cleaning sockets and then looking closer at your connectors and grounds.
                  $5 shipped?
                    Okay. Yay now to learn how to change a blinker. Might as well do both while I am at it
                      High resistance in the blinker circuit. Be it a blown bulb or dirty contacts.
                        buy more blinking fluid
                          Hyperblinker!!!!!
                          Leave Me Transaction Feedback
                            Hahaha have you seen the AAA commercial? Guy asks for turn signal fluid
                            Originally posted by trackjunkie21
                            when there is a choice between an e36 and another car, you choose the other car.
                              wait...what?
                              a guy with just under 3,000 posts on r3v doesnt know when his turn signals might be out or how to replace them yet?
                              FAIL
