HOW TO: Bring life to your glass fogs back to life
  • Nick_S
    • Apr 2011
    • 3658
    d this awhile back. Figured some of you guys may be more into this than spending $100+ on new glass fogs.
    Supplies
    -Sand paper, 80, 100, 180, 220, 320, 400, 800, 1000, 1500
    -Rust-o-leum clear coat
    -a buffer
    -compound and polish
    -Lamin-X (optional)
    -some beer
    Since BMW used glass lens for their fogs, they often get very pitted up from every day use. It's near impossible to avoid. So this will give many of you a cheap and decent alternative to buying new lens.
    Both my fogs were pitted badly but one was cracked and had water damaged so I bought a beat looking used one off another forum member so lets start with this. Both sides were similar and some pics are from one side, some the other.
    Grab your 80 grit and go to town on this, knock off as much grit as you can. Once you've got most of the heavy grit go with the 100 and again sand it for a bit. After that, go with 180 then finally 220. Should leave you around this...
    With this you can use the spray on clear and give it a nice layer of clear. This will leave already looking MUCH better.
    You could easily leave it here but there are still some deeper pits. Wetsand with 320 till its lookin smooth and re-apply clear.
    Gettin there
    Repeat but wetsand with 400 this time. Starting to smooth things out here. Repeat if you desire but likely it will be pretty good at this point so wet sand your final coat of clear with 800 then 1000 grit then 1500
    Then grab your buffer and compounds and polish. I personally used my Griots random orbital and 3M Perfect It compound and polish.
    A couple passes of either should leave you with a pretty surprising finish.
    At this point again you could leave it and enjoy your new found clarity in your fogs but being spray clear won't be super durable so I opted for some prolonged protection in the form of yellow Lamin-X. Only cost me like $25.
    Applied
    Boom!
    Total spent? Around $35 bucks.
    Hope this helps some of you guys :finger:
    Nick
    91 318is M50 swapped
    05 Honda Pilot
    24V swap thread
  • ///M42 sport
    • 3952
    thanks didnt realize you could sandpaper glass
    • ///M42 sport
      • 3952
      I guess same could be done with pitted headlights
      • Ceeker
        • Sep 2009
        • 2821
        Looks tons better; maybe it's the camera angle, but it looks a bit hazy after the clear and final polish. Is that just because you didn't go all out on the polishing or is this due to the brand of clear coat you used?
        • Nick_S
          • Apr 2011
          • 3658
          that was some haze on the inside.
          05 Honda Pilot
          24V swap thread
          • forex123
            • Aug 2011
            • 4
            I really like your website because you gave me about info and resource I've never seen that before. I' l stay tuned on your web site. Cyprus Things to Do
            • ethrtyiS
              • 8147
              that looks fantastic. i'll be doing this to all of my lights.
              「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
              「my feedback thread」
              • dieselbonds
                • Jul 2011
                • 15
                Good job they look great.
