I recently changed over my sealed beams to ellipsoids. I wired them in so that lows and highs work separately. but I am having a problem. My left high worked and then stopped. I wiggled the power supply side of the connection and saw sparking going on at male to female junction. I pulled on the wire and noticed it would go on and off.
Here is what I did so far to test: there are two lines going into one female connector from the car side. -normal - one is bridged to the low beam socket.
I tested the power line going in with a test light and it has power. I tested the other line and got nothing. Not sure if it should.
Both grounds seem ok.
I also swapped out the relays just to see if anything would change.
so, what could it be?
