can late model tail lights bolt straight into a late model 325is?
Yes late model tails will bolt straight into a late model body as you ask in the thread but then your thread title is "late model tails in early model body"
Late model tails wont fit an early body
Late tails will fit a late body
Early tails will fit an early body
Early tails wont fit a late body
Nobody answered because you seem to not know what the question is yourself.
I hope that clarifies it for you
Originally posted by der affe
first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
This made me chuckle.
Originally posted by FredK
However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
Only if the hypotenuse of the squares sides is ≤ to that of the Ø of the circular hole.
Anything is possible with some lube and some determination ;)
