driver side low beam only works when hi-beams are on.
This topic is closed.
    so my low beam just went out on my drivers side. and i figured, okay ill just replace it. then tonight. i was driving with my highs on so i don't get pulled over, and noticed in the reflection of a suburban that the low was on too!
    it shows the low beam check light on the panel when i turn on the headlights but if i engage the high-beams before actually turning the lights on the panel doesn't show the light until i turn the high-beams off..
    the drivers side low beam only works when the high beam is on for some reason... anybody know why?! what can i do to fix it?
    Originally posted by ApexGoblin
    well make sure your priorities are straight... e30 first :up:
    I would wait for an expert on this but, I believe your low beam filament burnt out.
    The high beam filament in your "outer/low beam bulb" still works but not your low.
    Also it can't hurt to check your fuses. Left and right bulbs are on different fuses.
      Its just the low beam filament as stated. Buy a replacement, and all will be well.
      The main (low beam, outer light) light has two filaments in it, one for high, one for low.
        TY buying a new 1 asap
          driving with the high beams on is a douchebag move, and is also more likely to get you pulled over than having a light out.
          Moral of this story?
            i disconected the inner HBeams, running outside Hbeams isnt so bad. will be buying new headlights soon (if $$ permits.)
              dude sealed beams are like $15, buy a new low.
                I throw eaten apple and pear cores at d bags like this.
                  that's because you're a waffleswaffleswaffleswaffleswaffleswaffles. i normally bury people like you in shallow graves. douchebag.
                    I punch fags like this
                      It was a joke you nitwit motherfuckers. Pull the cock out of your asses and fix your cars properly instead of blinding others and creating a hazardous situation.
                        Haha, funny joke cock breath. I know where you live.
                          Cool, good for you. If you can make it this far without being pulled over for non-operable headlights, I will shoot you on my lawn.
                          :finger:
                            I ain't going to waste my time with you curt westerfield. Fucking dickless waffleswaffleswaffleswaffleswaffleswaffles. I'll post your address and social security # publicly later
                              Go for it. I thought you said you were going to come and have a cocktail while I cooked some steak. Or did you want my cock in your tail? Cus I only do that after at least 2 bjs.
                              Congrats on learning how to use the search button and google though. Mad props. :razz:
