1991 325ix Defroster Not Working
  • CR 325ix
    • Sep 2011
    • 3
    My defroster does not work. The switch lights up but does not defrost???
    Any help would be a great help!!!
  • DRTSRFR
    • May 2008
    • 1836
    ...need a little more info...
    The fan blows but not hot?
    The fan doesn't blow?
    The slide control makes no difference?
    Rear defroster??
    Suspension tips here...
    http://www.r3vlimited.com/board/album.php?albumid=757
    • dogsbark26
      • Nov 2008
      • 533
      Simple electrical circuit. Trace power and ground. Does the wiring on the window itself show continuity? Most likely is one of those little wire decals on the window itself is broken. Many auto stores sell a product to repair. Example: http://www.frostfighter.com/prt2100.htm
      • CR 325ix
        • Sep 2011
        • 3
        Rear Defroster Not Working
        Sorry I should have mentioned that it’s the rear defroster. I will check the continuity. There is no visible broken lines that I can see? I will check it with a tester to be sure. A friend mentioned that it may be a relay that is located in the trunk?
        • dogsbark26
          • Nov 2008
          • 533
          Verts have a rear defroster fan.
          Do you have an ETM (Electrical Troubleshooting Manual) for you car? It will show circuits and wire colors, etc.
          Available here: http://wedophones.com/BMWManualsLead.htm
          • DaveSmed
            • Apr 2007
            • 1407
            The wire from the car to the back glass likes to break off...
            -Dave
            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
            Need some help figuring out the ETM?
