Where to buy connectors for Smileys / City Lights??
  • QUiKSR20
    • Jul 2011
    • 187
    Anyone know where I can buy connectors for Smileys / City Lights??
    Can I just goto a US dealer or is there a place online I can buy for less?
    I have searched and cant find much the depo wiring adapters are a joke.
    Convert your BMW E30 to Euro smiley headlights from sealed beams or US ellipsoids - wiring, connectors and what bolts straight up.
    Thanks,
    DG.
    13 328i F30 6MT Tuned
    95 325i E36 5MT Vert
    89 325is ( sold )
    92 Sentra SE-R SR20DET
    - DET Build Thread
  • davem
    • Jun 2010
    • 705
    That rts link you posted has the part numbers. Get them from anywhere you would usually get bmws parts - Pelican, Blunttech, the dealer etc.
    • QUiKSR20
      • Jul 2011
      • 187
      They look like just the connectors though, Not the pins that go inside.
      DG.
      89 325is ( sold )
      - DET Build Thread
      • davem
        • Jun 2010
        • 705
        look again - by the way you get these connectors and pins from a wrecker - if you check realoem.com you will see that they are used in multiple applications on multiple bmws, there's also a guy selling used ones in the for sale section, or you could get new stuff like I mentioned before
        • QUiKSR20
          • Jul 2011
          • 187
          Cool ill look for the used ones, I did search but didnt come up with much. Just want to install my new lights correctly.
          DG.
          89 325is ( sold )
          - DET Build Thread
          • QUiKSR20
            • Jul 2011
            • 187
            So im looking into placing my order from http://www.bmwmercedesparts.com/ or wherever but still unsure what the hell I need..
            Do I need 2 of each of the below connectors ( one each per side )
            • White Connector 61-13-1-378-417
            • Grey Connector 61-13-1-378-418
            • Yellow Connector 61-13-1-378-419
            And then pick whether I want to use skinny or thicker wire from here ?
            • Circular Connector 1.0-2.5 MM² 61-13-0-007-446
              (This is the bigger wire & recommended)
            • Circular Connector 0.5-1.0 MM² 61 –13-0-007-445
              (This is the smaller wire)
            And then buy 2 of those per connector for a total of 12 ?
            Unfortunately nobody goes into detail about this I have searched up and down google, this forum etc and have not found definitive answers.
            DG.
            89 325is ( sold )
            - DET Build Thread
            • nmlss2006
              • 910
              Suggestion:
              Automotive Light Bulb Foglight & Headlight Connnectors Sockets Receptacles Pigtails Wiring
              • davem
                • Jun 2010
                • 705
                My euro smileys use one yellow connector for the low beam and one white one for the high beams (so get 2 of each). Not sure which wires to get - probably doesn't matter?. As for the city lights, I'm not sure how they're wired up stock - I have these:
                • QUiKSR20
                  • Jul 2011
                  • 187
                  Thanks Guys! Im on my way home from work but will check those two links a little later.
                  DG.
                  89 325is ( sold )
                  - DET Build Thread
                  • QUiKSR20
                    • Jul 2011
                    • 187
                    http://www.r3vlimited.com/board/showthread.php?t=224128
                    So you think just 2 of those wires per connector? They look like they slide into the connectors.
                    DG.
                    89 325is ( sold )
                    - DET Build Thread
