When I pull the switch out to turn on my lights, my marker lights turn on but not my low beams or fog lights. When I flip my brights on, my fog lights, low beams and high beams all turn on. In order to drive at night now, I have disconnected my brights so that I can drive with my lows and fogs. Has anyone ever experienced this issue before or have an idea whats causing it?
It happened after my fuel pump relay blew and I had it towed to the shop. I could have easily changed the relay had I known where it was but after the car had an m50 swap its fuel pump relay was relocated. When looking for the relay, I pulled some relays and put them back in. After I got the car back from the shop it had developed this problem. The car is a 1991 318is.
