Picked up a set of these a few days ago, and have mixed feelings on them. They work, and are a shitload cheaper than stock, however the quality on them doesnt seem to be 100%. Issues are thus
Glass lenses: appear to have unevenness in the lens itself. Adjustment holes are poorly executed, and there appear to be bubbles in the optics themselves.
Frames: obvously lower quality plastic than stock, feels flimsy and flexible.
Connectors: This is the kicker.... the housing castings appear to be mirror images of one another INCLUDING THE CONNECTOR. Thats right, the connector alignment and shape is reversed. You will have to remove the outer casing to use this. also the pins are not centered in the connector body making fitment a bit of a bitch.
General construction: Appears to be light gauge stamped sheetmetal for the internal construction of the lights. screws are not the same quality nor are they cad plated for rust resistance.
General consensus: I would give them a 6-7/10 rating. not bad enough to avoid completely, but bad enough to try and find decent stockers instead. If you dont have fogs, they are better than nothing, and that is the best I can say about them. For 72 bucks shipped, they look better than an empty hole in the valance.
Heres a link to the fogs I got, for those that follow:
http://www.ebay.com/itm/170655753854...84.m1497.l2649
