Ok so I found me a set of ellipsoids to replace my old sealed beam set up on my car, the thing is I cant seem to find the info on what needs to be done to connect them?
They do not have any bulbs so I of course I would need them, I found out that I would need 9005 and 9006 but not sure which is for high and low.
Also I assume I would need a Male 9005/9006 adapter to be able to wire these in to the sealed beam connector thing using spade connectors, or to connect up an HID system right?
BTW My car came with HIDs installed on the lows, updated headlight from late model? and sometimes the engine seems to want to cut out when I turn them on and Im not sure why that happens
