drivers side hi beam works but low beam doesnt. help?!
  • smashed s4
    • 105
    hello everyone, new to the forums. just bought my 1987 325es.
    the highbeams work on both sides, but the low beams only work on the passenger side. But they all work when high beams are on. what could this be? should i try swapping lights first? or do you think its a wiring issue?
    thanks!
  • Liquidc3lls
    • 22
    are you running sealed beams or have upgraded your headlights, depo headlights or OEM?
    • smashed s4
      • 105
      Sealed
      • mr.vang
        • 4371
        switch and see
        • craiggroves91
          • Oct 2009
          • 3024
          Sell it
          Sent from my DROIDX using Tapatalk
          1989 BMW 325i SOLD
          1998 BMW Estoril Blue e36 M3/4/5 SOLD
          1987 BMW 325 (The Piece) SOLD
          1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
          • smashed s4
            • 105
            Switched headlights and still same
            Problem. Any ideas about wiring??
            • Wh33lhop
              • 11705
              Fuse. Driver's side low beam should be #13.
              paint sucks
              • smashed s4
                • 105
                fuse is fine!
                  • 37833
                  You swapped the low beam bulbs from left to right and still have the same problem on the same side?
                  The low beam bulb is a dual filament so the low beam filament could have burnt out in the one that's not working.
                  Grover Beach, California
                  BimmerHeads.com
                  • kyfdx
                    • Jul 2011
                    • 29
                    I have a similar problem...
                    Hella low beams, sealed high beams.. all were working normally..
                    Now, when I switch to high beams, the driver's side high beam doesn't come on, but also, the driver's side low beam (Hella) goes out.. additionally, the high beam indicator in the dash cluster doesn't come on...
                    Is this likely to be a problem with the sealed high beam or the dual-filament bulb in the low beam. (guessing that both aren't going to go out at the same time?)
                    • craiggroves91
                      • Oct 2009
                      • 3024
                      We fixed it. The fuse was oxidized a little, it had some gunk on it. We cleaned it off and bam it worked!
                      1989 BMW 325i SOLD
