need help on headlight alignment
  • ezlnh8u
    • Feb 2012
    • 254
    Hi there everyone, i have noticed that on my 90-e30, the left head light lights up far left and the right headlight lights up really low, that includes the highbeams as well, i was wondering if anyone can point me to the right direction on how to align them, if there is a knob that i have to turn? many thanks in advance.
  • jaywood
    • Jul 2010
    • 4528
    Do you have stock headlights? 90's came with sealed beams.
    • ezlnh8u
      • Feb 2012
      • 254
      no the head light is a projector, and the highbeam has swapable bulbs
      • davem
        • Jun 2010
        • 705
        There are two adjusting screws per lamp that can be turned by hand/flat head screw driver. Google some pics of e30 ellipsoid headlights to see how the reverse side looks. You'll have to remove the engine bay headlight covers. Drive a few feet away from a wall and make sure they are level.
        • bmwguy325is
          • May 2011
          • 1263
          I have found some body shops that will use an aiming tool for $50
          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
          • ezlnh8u
            • Feb 2012
            • 254
            ok, so i took it to a local shop that does headlight alignment, they told me the knobs are not working, they turn but dont adjust the lamps, do i have to buy new head lights? or is there another way to adjust them?
            • davem
              • Jun 2010
              • 705
              You need to inspect the moving parts and see why they're not working properly. Some of the clips could be broken, the adjusting screws could be seized up etc.
              http://www.realoem.com/bmw/showparts...32&hg=63&fg=05
              remove the head light covers (if you have them), and the front grills to remove them and take a look. The head lights are mounted to the rad support with 3 screws.
              • ezlnh8u
                • Feb 2012
                • 254
                thanks, will do.
