Aiming euro smiley lowbeams vertically?
  • flying_violin
    • Jan 2011
    • 325
    I ended up getting a set of the euro smiley headlights, as they supposedly have much better light output, look cool, etc... Ordered them from Germany (used, of course!) and this is what they look like:
    (For the other unit, hold your monitor up to a mirror.)
    Fantastic! I looked up some installation write-ups, and went out to improve the old daily driver. Installation was a breeze, and I thought the car looked rather sharp with the new lights. Then I waited for darkness to fall, and went for a drive. After hitting nearly every pothole within several miles, I came to the conclusion that the lowbeams were aimed much too low, although the highs seemed to be pretty good.
    The following day, I went out to the local hardware store and picked up a couple packs of washers, and stacked approximately four or five washers under the lower two mounting screws of each unit. That allowed me to at least see the potholes with enough time to brace for the impact when driving in the dark, but they were still aimed too low. The high beams were now very high beams, and were lighting up street signs a mile away! Fortunately the pattern is large enough that the bottom of the beam lit up the road in an acceptable manner.
    Several weeks later, when I grew tired of betting my oil pan, control arms, and whatever other suspension components against the diligence of the road construction crews, I removed the euro units and re-installed the US spec units. I really like the euro units, so I got all the adjusters working on them, except for the vertical low beam adjustments, shown in the bottom of this picture:
    I know that these were supposed to hook up to the interior adjuster knob, but is there a way to get them to raise the beam a little without having to hook up hydraulic lines to them?
    Alpine II 318is
  • Dirtboy
    • 458
    What you have right there is the hydraulic adjustable unit that is an option on the euro cars. They are used to adjust the aim of the beam if you have a car loaded down with stuff in the back. You can just remove them and replace them with regular manual adjusters. The ones on your US lights might work...
    Nürburgring info
    • davem
      • Jun 2010
      • 705
      Originally posted by Dirtboy
      might work...
      i've had both bosch smileys and hella ellips and i will say with 90% confidence that the US adjusters will work, even the mounting brackets for US/Euro ellipsoids are identical.
      • flying_violin
        • Jan 2011
        • 325
        Ah, thanks for the info! Also, I have the sealed beams, but I'll have to see if I can get one of those adjusters to work.
        Alpine II 318is
        • davem
          • Jun 2010
          • 705
          those will NOT work, the brackets and adjusters for sealed beams are totally different
