headlight lens restoration
  • harold30
    • Jul 2011
    • 180
    hi guys, i just bought a hella smileys and it has pittings on the lens. while searching the net i saw diy tutorials on how to restore using wet sanding and polishing with plastx. since, ill be doing it personally and its my first time, i would like to ask if anyone done this before and how it went? i am open for any comments and suggestions. tia!
    cheers!
  • KenC
    King of Kegstands
    • 14396
    Sounds like you watched one that pertains to plastic lenses. That will be insufficient to polish glass.
    Originally posted by Gruelius
    • harold30
      • Jul 2011
      • 180
      while searching solution in the net i assumed the lenses were plastic but i guess you just confirmed it that they were glasses. so the only way to get rid of the pittings is to replace lenses with new one, right?
      • KenC
        King of Kegstands
        • 14396
        There are a few compounds that will polish glass. An electric drill is a necessity. Google specifically for glass polishing.
        • jrobie79
          • Mar 2006
          • 2525
          there was someone on here who would do all 4 for like 50 bucks, with cerium oxide and everything....he had pictures of his work, and the results were nothing short of amazing...cant find the thread though
          1991 318i ---- 308K - retired
          • harold30
            • Jul 2011
            • 180
            the problem is i am halfway around the globe. i bought the smileys from germany, ship to new york and to the philippines and i just got it today. i been searching for diy and encountered wet sanding. but i don't think i can do cerium oxide on them (i don't even know what that is). anyway, ill just let it be, though, i can get use to it... thanks for suggestions guys!
            • jrobie79
              • Mar 2006
              • 2525
              clear coat em.. it'll help
              • harold30
                • Jul 2011
                • 180
                will try that. thanks man
                • dogsbark26
                  • Nov 2008
                  • 533
                  Cerium oxide is readily available, for example on Amazon but cerium oxide is um... mild abrasive. It is used as a final polish on telescope mirrors. You are going to need something more powerful than that to remove pitting unless you spend years polishing.
                  • Jszy25
                    • 352
                    I picked up some us ellips and Bosch smilies to refinish. Thinking about polishing the glass myself if it's going to be too much of a PITA
                    91' 318is - OBDI M52/ZF swap w/ S50 cams
                    • Voyd
                      • Jul 2011
                      • 47
                      cerium oxide is the only method I have had success with. You can get it on ebay on the cheap.
                      • dogsbark26
                        • Nov 2008
                        • 533
                        Hey Voyd, tell us more please. How did you apply it? By hand? Drill? What kind of buffing pad did you use? How long did it take?
                        • Jurt
                          • Nov 2011
                          • 347
                          Any more info would be great. I've got some head lights that's need restoring.
                          Feedback
                          http://www.r3vlimited.com/board/showthread.php?t=270560
                          • OnMy2ndE30
                            • Sep 2011
                            • 385
                            You can search youtube for polishing glass with cerium oxide and there are tons of how to videos. You are DEFINITELY going to have to use some sort of machine for the polishing, just like you would polish aluminum rims.
