Corner light connectors
  • Dirtboy
    • 458
    Anybody have a pic or part number for the corner light connectors? I'm trying to retrofit US bumper trim/lights to a Euro car and I can't tell what connectors the corner lights use...
    Nürburgring info
  • blazinxpk
    • 839
    please define corner lights.
    i am assuming you mean the turn signals.
    if so, please refer to the link. the link includes information regarding late model turn signal connectors including part numbers and pictures.
    • blazinxpk
      • 839
      if you need to find out what bulbs to use please refer to the link below.
      • blazinxpk
        • 839
        another link.
        shows all available light/electrical parts at pelican parts.
        http://www.pelicanparts.com/BMW/cata...ELlite_pg1.htm
        • Dirtboy
          • 458
          Nope, not the front turn signals. I'm talking about the corner clearance lights.
          Number 7 in the pic.
          http://www.realoem.com/bmw/showparts...59&hg=63&fg=10
          EDIT: should be side marker lights...
          Nürburgring info
          • EVillalonRN
            • Jul 2011
            • 386
            That's funny, you're doing the reverse of what I'm doing. I have those connecters on my car. I need the euro turn signals connectors. Want to trade?
            My Transaction Feedback
            • Dirtboy
              • 458
              LOL, I'm doing mine temporarily. I might be able to get you a handful of those connectors from the junkyard if you want to trade. I can also get you the part number as well.
              Nürburgring info
              • EVillalonRN
                • Jul 2011
                • 386
                I won't be putting my M-Tech1/euro bumpers on for a 2 more weeks. I would still like to buy those turn signal connectors. I would also like the part number since I can't find it anywhere, even on realoem.com
                • Dirtboy
                  • 458
                  OK, I got the side marker bulb sockets. I still need the connectors. Can someone just go take a couple pics of theirs?
                  Here's what they plug in to...
                  Nürburgring info
                  • blazinxpk
                    • 839
                    i will take pics of mine asap. not sure about today, but for sure tomorrow.
                    i have my connectors sitting around because i have euro trim and connected the wires directly to the city lights of the smilies.
                    i actually did like a 30 min search of trying to find them, its weird that there aren't any part numbers available online.....
                    • blazinxpk
                      • 839
                      the pics are located in the album
                      please click the link
                      Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
                      hopefully this helps.
                      • Dirtboy
                        • 458
                        Thanks man!!! That does help a bit. I just wish the pics on Realoem were better so I could find out the part number. The almost look like car speaker connectors they use over here. Hopefully I'll find something out soon.
                        Thanks again!!
                        Nürburgring info
                        • blazinxpk
                          • 839
                          i have euro smilies and did not have the connector for the high beams. so what i did was connect some speaker quick disconnect female plugs and and slip those onto the pins. i then used a pair of pliers and squeezed them as tight as possible onto the pins.
                          on one side of the quick disconnect connector is where you crimp the wire and the other side gets slipped onto the pin and crimped with pliers to stay on.
                          this is an EXAMPLE of the connector i used:
                          http://www.amazon.com/American-Termi...2015340&sr=1-3
                          i will take pics of how i did my wiring for the high beams when weather permits.
                          this method is always an alternate option to using the actual connector. i used this method couple of months ago and it is still holding up.
                          • Dirtboy
                            • 458
                            BTW. If you don't want those side marker connectors any more I'll take them off your hands...;-)
                            Nürburgring info
                            • blazinxpk
                              • 839
                              did you ever find what you needed??
