Adding Euro Sidemarkers?
  • 325 eta
    • 472
    i like these on the spoiler
    • Ryan Stewart
      I Love Miatas
      • 8978
      When the weather gets normal my car is going back in to have mine installed. I got the smoked ones.
      Factory they came a little lower than what you have but in all honesty who the hell is gonna notice that?
      Im now E30less.
      • sweetride01
        • Apr 2004
        • 713
        If you wire them up to the front turn signal (I presume that's how they're wired in Europe???), then in the US won't they be 1/2 on with sidelights, and full on with turn signal? But the bulb is not dual filament, so this would seem a problem.
        Anyone have the answer (Ryan?)
        Moving sale: Everything Must Go!
        FS: 2001 740iL Sport, low mileage..... SOLD
        FS: 1990 Mtec II 325iS, $12,0K OVNO
        FS: 2003 Honda Odyssey EX-L Navi..... SOLD
        FS: New Rieger lip, lachsilber metallic (WILL INCLUDE W/e30!!)
        FS: Very rare, new lachsilber metallic E30 Aero pack sideskirts... (WILL INCLUDE W/e30!!)
        Extreme 325iS (well, slowly getting there, anyway)......
        Almost too many mods to list ;-)
        • sdcabrio
          • 370
          They are only meant to be a flashing turn signal/indicator (thats how I wired mine, just splice into front signals.) I think if you knew what you were doing you could wire them to stay lit with the parking lamps and then blink with the turn signals. I 've seen that done to a set of front U.S. side markers that are just in front of the wheel well.
          • sweetride01
            • Apr 2004
            • 713
            Exactly... but the front turn signal here in the US is also the parking light... or are there 2 wires running to it, one for the signal, and one for the parking light function?
            • sweetride01
              • Apr 2004
              • 713
              Bump
              • robrez
                • Jul 2008
                • 3376
                Bump this thread. I'm getting ready to install a set of repeaters. It is my understanding that they blink when you put your blinkers on, but otherwise, they do not light up.
                I'd like to mod them to come on when with my parking lights and blink with my blinkers. What kind of wiring does that require? BTW, I referring to the orange lights on the fender.
                January 2012 COTM
                • DaveSmed
                  • Apr 2007
                  • 1407
                  Depends if the ground is isolated. If the ground for that repeater bulb does not touch sheetmetal, then its simply a matter of one wire to the parking lights, one to the turn signal.
                  -Dave
                  2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                  Need some help figuring out the ETM?
                  • gearheadE30
                    • Jun 2007
                    • 3734
                    You'll want some diodes in there too to keep current flowing the right way or you could get some weird feedback.
                    Project M42 Turbo
                    • DaveSmed
                      • Apr 2007
                      • 1407
                      Nope! Diodes would make it work improperly.
                      That wiring trick works because the bulb is polarity insensitive. Add a diode and it will either light up and blink only with the parking lamps on, or blink only with the parking lamps off.
                      -Dave
                      • E30 Wagen
                        • Jul 2005
                        • 3432
                        Originally posted by gtopaul
                        Did mine a few years ago. Pretty easy job. Seems like people mount them all over the place on the panel but mine came from BMW with a template to cut the holes so I think they're probably right.
                        Paul
                        Does anybody have any more info on this template? I will be installing sidemarkers on my e30 and I want to know the exact spot to cut the fenders.
                        My Feedback
                        • e30blitz
                          • May 2013
                          • 61
                          Bumped
                          • e30serg
                            • Dec 2006
                            • 562
                            PM me you email. I have an installation pdf. Here are the dimensions, but the pdf also has a bunch of wiring instructions.
                            • GT BMW E30
                              • Nov 2008
                              • 2491
                              I have an issue. Just installed my euro side markers. DR side bulb stays lit and blinks. PS side just blinks. On both sides I have them wired the same(ground wire and blue wire). after some searching i may need to check and see if bulbs are double filament. Any other suggestions.
                              • Cgannon
                                • Mar 2014
                                • 31
                                Could you run the wires from the US side markers to the Euro ones and fill in the trim? No sense in having both and it would just look odd. Any where know where I could get a diagram of where to cut the whole and for the wiring?
