Ellipsoid City Light Connection
  • Eurospec
    • 2611
    Having installed euro trim on my bumpers sometime ago, I've just realized that splicing into the side marker circuit will be difficult now that I've covered them up . Am I correct or will I be able to access the sides without removing the trim? Has anyone ran into this problem?
  • royalflush313
    • Mar 2004
    • 2070
    If you have Euro Trims, you don't need to splice into sidemarker wires. The sidemarker wiring is long enough to reach the headlight housing.
    You just need to solder on the blue (?) city light plug, and you are good to go.
    You don't need to remove the bumper trims again, if i recall correctly, you can reach the wiring easy enough if you have your headlights off.
    ~ Go Canucks Go! ~
    • Eurospec
      • 2611
      Very good, TY much.
