e30 Brake lights question
  • Laernu
    • Jul 2009
    • 40
    Im finishing up my 1jz swap into my e30, and im having an issue with my brake lights not coming on because i removed the cruise control wiring harness thinking i did not need it.... (dumb me) im waiting for my new one to come in as im typing this. My question is, will the brake lights work if i dont connect the wire for the servo?
    (Connector D)
    Thanks
    The brake lights are not dependent on the cruise control, though a signal from the brake light circuit is an input to the cruise control. Check the switch mounted on the bracket in front the brake pedal.
