my euro turn signals are missing pins in their connectors, so will the US late models fit? o know the lenses are the same so they should work right?
US late model turn signals fit in euro bumpers?
Tags: None
I'm looking at one of each right now, and if you are speaking of individual wire connectors in the plugs, one is a three pin round connector, ant the other is a two pin blade connector. -
does the early and late model US turn signals fit the same 3 pin oval connector? i can make something up if not but i just want to know if the late model US housings will fit into the Euro bumpers?Comment
damn...well i just needa way to wire it up then...any way to rip out the internals and kinda install a 3 prong connector? idk cant find much info on this and just trying to get these to work :PComment
Maybe drill it out and high temp epoxy the three prong connector from your late model signals in? Are you putting euros on a late model?Comment
Just buy new ones that are not missing pins?
http://www.ecstuning.com/BMW-E30-325...Body/ES173451/
http://www.ecstuning.com/BMW-E30-325...Body/ES173452/
$34/each.Comment
