"middle" brake light bulbs wont turn on, e30
  • Afredo
    • 349
    1989 325i coupe. the "middle" brake light on both sides stopped working; replaced both bulbs, 5008's, still not working. does this mean the circuit somehow burned out on BOTH sides for the same bulb in the bulb "housings"? i feel like this is highly unlikely. help!
    "Once more into the fray."
    • 37833
    What do you mean?
    On late model E30s there are 3 brake light bulbs. One in each tailight (on the outside closest to the turn signal) and one in the center mounted 3rd brake light.
    Grover Beach, California
    BimmerHeads.com
    • Afredo
      • 349
      Originally posted by MR 325
      What do you mean?
      there are 4 bulbs in each housing. 3 appear to be the same size and the 4th smaller, type 5008 bulb. the 5008 bulb is a brake light bulb and neither side works. I need to know if there is a fix for this or if I need to replace the housings.
        • 37833
        Sure there are 4 bulbs in each housing.
        1. Blinker
        2. Brake light
        3. Running light
        4. Reverse light
        There is only ONE brake light bulb in each tail light.
        BimmerHeads.com
        • Afredo
          • 349
          1. Blinker
          2. Brake light
          3. Running light
          4. Reverse light
          that's bizarre then, because when i have the brake pedal depressed, both sides light up, but the check panel still says there is a problem with the brake lights. does this include the 3rd upper brakelight as well? i didnt think to check that.
          • gearheadE30
            • Jun 2007
            • 3734
            The third light would do it. Also, I forget which does it, but either the brass or the silver base bulbs is also known to cause the check light to turn on because they have a different resistance.
            Project M42 Turbo
