I've had some on my car for the last 8mo's. Work fine, fit perfect, look just like OE only with plastic lenses instead of glass (if the OE's are even glass).
My car didn't come with factory fogs so I wired them in with my headlights, that way they are on as long as my headlights are on but turn off when I hit the high beams.
Thats good to know. I actually prefer to plastic lens, but I'm going to lamin-x them regardless.
i bought a set last year to replace my original set with cracked lens.
i didn't like the brackets on the ebay fogs. the brackets on the ebay fogs are flimsy while the oem ones are sturdy and have almost no play. so i swapped the brackets with the oem one.
after installing and wiring them up, one side didn't work. took it out and tested with a multimeter. one prong didn't have enough solder so i fixed that.
ended up re-sealing the lenses with a bead of silicone and put lamin-x film to protect them.
so far they are holding up well. for the price i think they are worth it.
Thanks for the feedback. I did hear similar reviews, but for $50 and all the likelihood of them cracking, seems like a sweet deal.
