Stupid question
  • 91e30325i
    • Apr 2011
    • 57
    Stupid question
    Hi I just bought a set of ellipsoids and i am curious of what all i need to switch my old lights.
    I have the pigtail conversions but wasn't sure if there is anything i need before i put them in.
    P.S. if anyone has a driver side high beam lens and metal cover i am interested in buying
    Thanks
  • JinormusJ
    • 6887
    Just need to splice in the pigtails to the wires and, this should be obvious but, make sure you have bulbs and power going to your lights. As long as you have the right connectors, they should be plug and play once you have the wires spliced
    • 91e30325i
      • Apr 2011
      • 57
      Ok cool i appreciate it i was just making sure i have everything before i take my lights out.
      • Fourbanger
        • Jul 2011
        • 335
        Pin 30 to 30 on relays K3 and K4 (if I remember correctly, you might want to double check) to keep the lows on with the highs:
        And the sealed beams are dual filament so you have high and low power running to each low beam bulb, just tape off the extra.
        • lambo
          Captain Scene Points
          • 10953
          I need to do this...
          • Fourbanger
            • Jul 2011
            • 335
            I just fanned out the stripped ends of a piece of stranded wire and stuck them into the appropriate sockets before pressing in the relays. No problems since I installed them a couple years ago.
            That said, I cannot be held responsible if you die in a horrible car fire.
