Help with hi-beams!!!!
  • e30frosh
    • Dec 2004
    • 2170
    Just did the smiley conversion on my 87 and was wondering how to get all four lamps to illuminate when the hi's go on. I figure it's just a relay jump. If someone could gimme the right relay that'd be jus fine!
    Every day I wake up we drink a lot of coffee and watch the CNN
    Every day I wake up to a bowl of clover honey and let the locusts fly in.
    Lobsterbacks attack the town again
    Wrap all my things in aluminum
    Beams of darkness streak across the sky
    Pink rays from the ancient satellite
    Every time I look out my window same three dogs looking back at me.
    Every time I open my windows cranes fly in to terrorize me.
  • Jordan
    • 12911
    Wrong.
    Just twist the 2 hi beam + wires together. duh.
    https://mtechniqueabs.com/
    • e30frosh
      • Dec 2004
      • 2170
      Thanx...I think. Good delivery on your answer to an honest question. Ass.
      • Jordan
        • 12911
        See if I help you again.
        • Jand3rson
          • 37587
          Adding "duh" at the end of your post probably didn't help matters much.
          • Jordan
            • 12911
            This problem and fix has been covered in umteenbillion threads.
            I should have broken out the you fucking but no. I helped the stupid shithead instead.
            • asubimmer
              • 6482
              maybe we should sticky a write up? maybe that would help since its sooo common.
              • Eurospec
                • 2612
                Are you ever going to clean your act?!?!? What's with the blatant remarks as of late? Have some respect for others that lack the knowledge that you possess...come to terms with it already.
                • MrK
                  • Jan 2006
                  • 709
                  Jordan may not be nicest guy here, but he's got a lot to offer when it comes to e30 knowledge and exp. So don't sweat the small stuff.
                  This is your M20 on steroids:
                  • permit
                    • Mar 2005
                    • 3363
                    I'd rather never have my question answered than have to listen to Jordan bitch about how glorious he is.
                    • Eurospec
                      • 2612
                      I recognize that however, his approach isn't appreciated many times.
                      • CGDoig
                        • Nov 2005
                        • 348
                        I don't understand why no-one answered a simple three second question to answer. Yes jump pin 30 to pin 30 on the high and low relay. here guys i'm gonna post one more so you can see how easy it is.
                        '05 Jetta TDI
                        '87 325iS: Facelift, Hella Smoked Ellipsoids (RIP)
                        '80 320i: 500lbs lighter, Rally/Drifter (SOLD!:( )
                        '90 Jetta: Stock Daily Driver (SOLD)
                        • CGDoig
                          • Nov 2005
                          • 348
                          Jump pin 30 to pin 30 on high and low beam relays.
                          '05 Jetta TDI
                          • e30frosh
                            • Dec 2004
                            • 2170
                            I did try the wires together...no helpy...C, thanks for the quick reply...
