ok so my reverse lgihts are bust and out... i know that it can either be a switch which is broken, or it could be a wire going to it which has been the dammaged...
i took of the shifter boot, (i drive a 2 door) so the wires for the windows where there, and all messy after cleaning it up i noticed a pair, a green and i think white wire...
heading off down to the bottom of the shifter... they are fine and not cut at all... they disappear into a rubber join looks kinda like a mini plundger..
i have a gear lock that has a big arse steel plate welded on down there and ti comes thru my boot... and i couldnt get the rubber seal of from around the base of the stick shift... how do i get to the switch, and what else could be wrong? down there.. i tried looking around but couldnt get past the rubber thing, should i climb under my car and have a look see, or just force my way past the rubber?
