Hi guys,
I have a 91 318is. My low beams only work when I have it in high beam mode for some reason. I had the solid headlights before and I thought it was just the bulbs that were out so I purchased the ellipsoids euro headlights wired everything up and put on some HID's for the low beams and regular H1 halogen bulbs for the high beams. Still the same thing. Foglights work perfectly. No headlights only work in High beam mode.
I have checked the relays K4 and K3 and switch them out with the horn relay to check if they would work. still No go. Could it be my the malfunction switch (high/low beam and turn signal switch) went bad? Any suggestions? Thanks
-Mike S
-Mike S
