headlights from 740i into e30 325i.
  • Poeman446
    • Jun 2013
    • 227
    i was browsing my local junkyard today and came across a 740i. it was an e34 i believe. cani use the hella smiley lights from those to go into a e30 325is? they look very similar, but i dont think the fronts of them are as convex, and they may be a bit bigger. Does anyone know if this swap will work? Thanks!
    • 37827
    The 7 series you're thinking of is a E32. The E34 is a 5 series.
    The E32 and E34 lights interchange but neither are a direct fit in to the E30.
    Classic BMW Specialists
    Santa Clarita, CA
    www.BimmerHeads.com
    • AwakenNoMore
      • Dec 2010
      • 1291
      ^ This, If you get them ridiculously cheap you could cut off and re-glue the mounting tabs in the correct place but that's not ideal at all. Keep an eye out for a set of E30 ellipsoids in the junkyard. I happened upon a set for $40 just had to replace the smashed passenger high beam.
      1991 325i - "Scambles" The Daily Driven lightly modded.
      1988 Mazda RX-7 TII "Mako" The Free Dorito
      bacon by Jared Laabs, on Flickr
      • Roysneon
        • 4505
        Aren't the e32 elips able to be put into e30 headlight buckets? Or something like that?
        Originally posted by mbonanni
        I am a pursit now.
        • AwakenNoMore
          • Dec 2010
          • 1291
          Perhaps I wasn't clear enough. The mounting tabs ON the ellipsoid bucket are in the wrong spot. They do not fit as is.
