1991 325IX Front turn signal light ground location
  • dpgc44
    • Aug 2012
    • 11
    I have tried google for the diagram. Is the ground for the turn signal located where the relay switches are? I have a bad ground for my right signal where it does not work. We had a Ferrari tech check it out for me and said that my ground is faulty. Any help would be great. Thanks!!
  • AndrewBird
    The Mad Scientist
    • 11898
    Wiring diagram can be found here:
    325i should be the same or very close. Either that or use the 90ix manual.
    Either way you want splice 100. Should be right behind the headlight. Start at the turn signal and un-wrap the harness until you find the problem.
    • dpgc44
      • Aug 2012
      • 11
      awesome thanks Nitro!
