okay so my fog light for the passenger side does not work. I put a light tester on the number 30 fuse and nothing lights up, i put it on the number 29 fuse and it lights up. When I hit the fog light switch the light on the cluster doesn't come on. Should I get under the fuse box and see whats going on with the pin under number 30.
Fog lights Fuse help
Tags: None
I was lucky enough to solve this problem by replacing the #30 fuse. I have a '86 and have not checked the wiring diagrams for any other year but it is probably similar for each year. If you haven't already, I would check the connection to the fuse. You can find your diagram here
Good luck if you haven't already fixed this.
