right side of car out
  • tjmonsen5
    • Jan 2006
    • 232
    well i just got some smilies, and i got the driver side working, except i couldnt figure out the DRL. Now i cut all the wires the same as i did for the driver side, but im not getting any power. The passenger lights dont work, i tested high beam and it works but the low doesnt. both passenger side running lights are out, but the blinkers work, and they run double speed. The dashboard lights are out, and there are 4 lights that are lit on the check panel. Too bad i cant read them because they are in german. So, my question is... did i blow a fuse? or should i take it to the dealer and have them wire it all up.
  • golde30
    • 11464
    check yer fuse box for blown fuses.
    when yer working on any kinda wiring, u wanna make sure u unhook the battery first. which you should do now, and go recheck yer wiring.
    IG: @Baye30
    • AndrewBird
      The Mad Scientist
      • 11898
      You might have crossed a ground with a power lead or something and are powering a ground instead of the light. Check for blown fuses. If there is one, check the wiring as said above.
      • tjmonsen5
        • Jan 2006
        • 232
        im thinking a fuse blew because im not getting any power to the passenger side of the car. the passenger lights are not hooked up, they are on my garage floor. I did have power when i checked the connectors with my volt meter. But when i cut off the connectors, i was double checking the volts and then i got a big spark and the front blinker blew. BUT, it blinks, but the running light doesnt work. Weird.
        Do the city lights connect to the blinkers or the side lights?
        I cant get them to work.
