Ok...I have done quite a bit of searching for the cause of this. My car has Catz HID's 6000k kit. When I turn them on, both come up bright. Then the driver's side slowly fades to a pink/purple color. I checked all of the wiring, grounding and everything is secure. I even swapped ballasts and ignitors and the problem stayed with the driver's side. The passenger's side is still OK. I also checked the fuses and noticed that the 7.5 amp fuses are still in #13 and #14. Per one DIY I read...these are the headlight fuses. So I think that I should try swapping out the 7.5 amp fuses for 10 amp fuses. Otherwise...I am fearing that the bulb may be the issue.
Any thoughts? I also did some searching on Catz website and other places for just the HID bulb. Where and for how much can I get one?
Thanks!
jason
Thanks!
jason
