No Dash Lights, Right Rear Tail Light and License Plate Light
  • Steve Corbett
    • Jul 2012
    • 449
    My 89 325I is acting up. I have no right rear tail, license plate or dash lights. Checked fuse 23 good, bulbs are good, no power at tail light. A few weeks prior to this my tach and econogauge stopped working. Also my left turn signal is acting weird. Sometimes it will not work, just hear a rapid click of the flasher unit. But if I use the passing position instead of the full turn position it works fine, even if I hold it there for a few seconds and slowly move to the full turn signal position. WHAT The Heck??
    Steve Corbett
    1983 528E Scrapped
    1983 528E Sold
    1984 745I
    1984 325E - Sold
    1989 325I Bronzit-Sold
    1989 325I Zinno
    1988 635CSI
  • hammrdwn510
    • Mar 2014
    • 132
    Similar situation here except it's my drivers side tail light and drivers side front parking lights that are out only, turn signals work tho.
    The dash and license plate lights have only NOT worked a handful of times, but all the tails did at that time.
    91 325i
    Haven't been able to test anything yet other than to verify that bulbs are still good or check out schematics
    • spdracrm3
      • Sep 2009
      • 959
      so you say fuse 23 is "good" does that mean you pulled it out and looked at it and saw it wasnt blown or do you have power at the fuse ? that fuse as you can see in the ETM is the power for all those thing you mention as being out , so its where to start ,if you have power there next step is to check at the light switch ,the power from fuse comes in on GY/GN grey-green wire thru connector C103, if power to light switch is ok check power out on GY/RD grey-red for power with switch on to park position, if no power out switch is bad , if you have power out you have a wiring issue on that GY/Rd wire ,it goes back out thru C103 so its another place to check those two wires..
      Angus
      88 E30M3 X2
      89 325IX
      92 R100GS/PD
      • Steve Corbett
        • Jul 2012
        • 449
        I checked Fuse 23 with a volt meter. Will check the C103 and switch later today.
        Thanks.
        Steve Corbett
        1983 528E Scrapped
        1983 528E Sold
        1984 745I
        1984 325E - Sold
        1989 325I Zinno
        1988 635CSI
        • Steve Corbett
          • Jul 2012
          • 449
          Update
          Checked C103 plug, had no power at pins 8 or 9. Pulled Fuse #23 and checked and had continuity between fuse socket (non powered side) to C103 pins 8 or 9. Replaced Fuse #23 with a known good one and now Lights work, still no Tach and Econometer yet. So I guess even though the fuse had voltage on both terminals it was not making good contact with the socket. Now on to the Tach issue. I am assuming the Turn Signal issue is a corroded terminal on the switch as it is intermittent.
          Steve Corbett
          1983 528E Scrapped
          1983 528E Sold
          1984 745I
          1984 325E - Sold
          1989 325I Zinno
          1988 635CSI
          • audiquattrot
            • May 2008
            • 3836
            had a similar issue where the wrong (larger fuse) was put in #23. Something must've shorted, and right side lights and half my dash lights went out including my Euro clock backlighting.
            Pulled the cluster, and turned out the circuits within the cluster fried, so I had to swap that out to get everything working again. There were clear burn marks all across the circuits.
            www.instagram.com/snwmble
            #snwmble
            Current:
            '05 BMW M3 - Silver Grey/Imola Red
            '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
            '15 Mini Countryman - Blazing Red/Carbon Black
            Past:
            '01 Audi Allroad - Light Silver/Platinum Saber Black
            '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
            '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
            '90 BMW 325i - Schwarz/Tan sport *Sold*
            '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
