"Door" function of dome lights don't work... On switch functions normally?
  • jprastrullo
    • Jul 2012
    • 169
    What is the issue here... switching the position to "on" allows the light to turn on, but the "door" function doesn't work.
    What is the usual culprit here?
    My '87 Alpinweiß 325is Build Thread | Parts FS | Parts Wanted | Feedback
  • Red88
    • Nov 2008
    • 1161
    Curious as well. I always figured there was no door function it then I saw the buttons in the front of the door jam. Can't figure it out.
    Have you made a purchase from www.blunttech.com recently?
    sigpic<< wrecked
    • ELVA164
      • 4861
      Remove the light and inspect it. The switch functions by moving a metal plate from one side to the other, and if the contact on one side has corroded or broken off that side of the switch won't function. Also, the wiring and/or plug on one side may be messed up somehow.
      • jprastrullo
        • Jul 2012
        • 169
        I've inspected the 2 metal plates... obviously one is functioning fine.
        The one that isn't functioning doesn't have any noticeable defects... What do you recommend cleaning this with?
        Lastly, if the wiring/plug is messed up on the other side -- then am I screwed? haha.
        • ELVA164
          • 4861
          Mine was completely broken so it was easy to see it was messed up :p If you flip the switch, the plate definitely makes positive contact?
          You can clean the plate with something like scotchbrite and brake parts cleaner, but if it's excessively burned there may be something else going on. Most likely, the wiring would be burned/melted near the bulb itself. Obviously it could be messed up further down the line, but I honestly don't know exactly where the wires pop out for you to inspect.
          • vpilarrt
            • Jun 2006
            • 2096
            Could be the door switch itself. The contacts can get corroded. Remove the switch by removing the Philips head screw and inspect.
            • E30335i
              • Feb 2014
              • 1035
              Revived. When my door is closed its dim but when open its off. Pretty stumped on it as I checked the connections on door and on some light itself
