Low beam issue
  • grke36m3
    • Aug 2014
    • 86
    Low beam issue
    Hey guys I noticed the other day my right lowbeam was not working. So I figured I just needed a bulb. But then I noticed when I flick the high beams on it turns on. Then I thought maybe it has two light in one. And the low beam is dead. I change the bulb and still have the same issue? Is there a relay or fuse I can look into for this? Or should I follow some wiring to see if a wire is cut or something? Thanks for the help guys.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
