Any easy way to get to turn signal wiring without removing -- metal bumpers?
  • jprastrullo
    • Jul 2012
    • 169
    Hi r3v,
    I recently swapped aluminum bumpers with my buddy (mine was shitty) and didn't test the turn signals -- and now I get the fast blinker.
    The bulbs are new, I'm sure it's the wiring/connection behind the buckets.
    Is there any easy way to get behind them without having to remove the bumper? It was a total PITA.
    Anything here helps!
    Best,
    JP
    My '87 Alpinweiß 325is Build Thread | Parts FS | Parts Wanted | Feedback
  • Reichart12
    • Aug 2012
    • 2168
    Check the bulb again to see how well its seated. Ive replaced bulbs in the turn signal and it blinked fast after. So I went back and made sure it was in evenly and had good contact in its seat. Fixed up my problem.
    If that's not it youre stuck taking the bumper back off or working on your reach around hand skills.
    Instagram: Reichart12
    • Das Delfin
      • Sep 2014
      • 2293
      Stick your head under the car and look at the back of the turn signal? It should be pretty obvious when you get there. Mine didn't work when I got my car. I went in to clean all sorts of corrosion and low and behold - they weren't even plugged in
