help. ellipsoid rebuilding
  • 325isdan
    • Jun 2007
    • 190
    Hi all.
    I need some tips on reassembling my ellipsoids. I've already broke a $3 black bushing.
    Do you put the black bushings on the adjuster screw first or in their mounting spot first?
    I put them in their mounting spot first and then had to force them onto the screw. Of course the amount of force needed to get the screw into the bushing broke the bushing. so 2 out 3.
    There must be an easier way.
    Any tips?
    thanks
  • rcsoundn1
    • Nov 2012
    • 3361
    were they new or used bushings? I think they are press fit, but I am not 100% sure. Some one will chime in with more details
    • 325isdan
      • Jun 2007
      • 190
      they are brand new bushing and adjusters. yes they are press fit but for how hard I had to press them it literally pushed the bushing through its mounting hole which ultimately broke the bushing.
      • rcsoundn1
        • Nov 2012
        • 3361
        This is the more appropriate place for the question, the sub forum for "lighting in appearance. I have made the same error
        • 325isdan
          • Jun 2007
          • 190
          hi thanks. just realized what I should have done. used lots of lube. doh!
          • rcsoundn1
            • Nov 2012
            • 3361
            "Thats what she said" badum cha
            • 325isdan
              • Jun 2007
              • 190
              that is usually what she says. lol
