Euro Smiley Questions
  • elbrack
    • Jul 2013
    • 176
    Hey All,
    I've finally gotten around to looking into installing my euro smilies and I've run into some potential issues.
    I've got 3 pigtails pictured below and the black one does not fit in the last spot for it on the back of the low beams.
    What do I need to do to solve this? Is it possible to get the connector somewhere else?
    Thanks
  • noid
    • 1537
    The black "connector" is just a black housing around two normal plugs, if you remove the black plastic housing you will be left with just the connectors which will then fit into your lights.
    Then go ahead and just order a new plug housing:
    White Connector 61-13-1-378-417
    Grey Connector 61-13-1-378-418
    Yellow Connector 61-13-1-378-419
    Circular Connector 1.0-2.5 MM² 61-13-0-007-446
    (This is the bigger wire & recommended)
    Circular Connector 0.5-1.0 MM ² 61 –13-0-007-445
    (This is the smaller wire)
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
