OBC and tachometer lights not functioning when headlights are on
    During normal daytime driving my OBC is easily readable however when I turn on the headlights the backlight goes out. The tachometer backlight is also not working. When this first started occurring it would only happen intermittently and both lights either worked or didn't. Is there some sort of relation between these two lights? I have replaced and tested the tachometer bulb and also checked the contact of the bulb and it all seems good. Has anyone seen anything like this or have any ideas?
    had a similar issue, and found out I had fried the instrument cluster circuit board. I opened up the cluster, and saw the burn marks. Yes the back lighting for the OBC & Tach are related. Have u checked the fuse in the fuse box to see if its good?
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
      Thank you.
      I haven't check the fuses yet thinking that was unlikely since it would work and stop randomly, although it hasn't worked correctly in a while. I will definitely check that. Can the instrument cluster circuit board be replaced or do you just have to replace the entire unit?
        I just replaced it w a donor one my friend had laying around. I swapped my gauges and bulbs to the replacement one. Was easy to swap.
        Here is what mine looked like burnt
        Be sure that the right amp fuse is in there. In my case I put a 10amp fuse as opposed to the proper 7.5a fuse....#23 fuse...and there was a short in the system that fried this
        #snwmble
        Current:
        Past:
