Proluman Hid install
  • formula driver
    • 2263
    I just got my kit yesterday and theres not instructions for installation. It looks fairly strate forward but I have a couple of questions. Theres a set of wires with a tel connector on the end with male spade connectors on the opposite end. Where do the male spade connectors plug into? Also is there any wiring ran from the car to the hids at all?
    edit...I saw the mistake in the thread title.
  • formula driver
    • 2263
    Also....do I need to switch to 15 amp fuses for the low beams?
    • MikesJo
      • Mar 2004
      • 989
      I think I'm using 10 amp fuses on the lows.
      Vancouver Portrait Photographer
      E30 M3 Wallpapers
      • herragge
        • 361
        I'm going to update this thread because I just bought this kit and I'm not sure where the spade connectors go either.
        Anyone care to add somethign helpful?
        Mike
        • smonkbmw
          Professor
          • Jun 2006
          • 4549
          pull the spades out. those are for if you dont have 9006 connectors (jam the spades into a terminal).
          • herragge
            • 361
            Yeah I don't have 9006's bulbs. I have H1 for euro ellipsoids.
            So where do the spades go?
            Mike
            • smonkbmw
              Professor
              • Jun 2006
              • 4549
              ummm i think youre gonna have to purchase some 9006 connectors. they plug into the ballast box....you would still pull the spades out. i have euro smileys also with h1 bulbs. but i had elips already.
              • JDMpower
                • Sep 2006
                • 1771
                Toss some pics in the thread.
                '89 "is" = M technic II build mode.
                • formula driver
                  • 2263
                  Neither one of these pics help much in the way of installing but they do show where my ballast's are...
                  You have everything you need. Take the wires for the low beams and solder in spade connectors and hook them up to the ones supplied with the kit. either that or just cut out the spade connectors from the kit and just solder the wires together. I used spade connectors, its a nicer install this way.
                  LMK if you have any more questions.
                  If you look closely you can see how I kept the spade connectors...
                  -Paul
                  • herragge
                    • 361
                    Thanks man! I knew you had figured out how to do em because I saw the HID's in your sig. Didn't want to PM for searching purposes.
                    Thanks again
                    Mike
